The Nuki Smart Lock is designed for standard compatibility with a wide range of Smart Home systems.
homee is a fully modular Smart Home central unit. Thanks to the so-called Brain Cube and the expandable modules, you can easily integrate your Nuki Smart Lock into a wide variety of Smart Home systems. homee is compatible with Z-Wave, Zigbee, WLAN and EnOcean. You can create individual scenes and connect your Smart Home devices to each other.
Setup
Pairing your homee is done via the Nuki Bridge HTTP API.
- Open the menu in your Nuki app and select “Manage Bridge” to connect your Nuki Bridge.
Enable the Bridge HTTP API
Open the Nuki app, go to “Manage Bridge,” and enable the “HTTP API".
You can find out how to access the bridge settings here: Manage Bridge settings - Make a note of the IP address, port, and API token.
- Open the homee app and search for compatible devices.
- Enter the relevant values to connect your Smart Lock.
