iHaus
The Nuki Smart Lock is designed for standard compatibility with a wide range of Smart Home systems.
iHaus
Smart Home is designed to make your life easier, safer and more comfortable. No matter if you want to wake up sooner or later in the morning depending on traffic conditions, or if you want to install atmospheric lights and intelligent sound systems in your home, the iHaus app offers you these options and more to control your technologies – regardless of manufacturer. All you need is the iHaus app on your smartphone and the door to an intelligent, connected home is open.
Setup
Pairing the iHaus app is done via the Bridge HTTP API.
  1. In the Nuki app, open the menu item “Manage Bridge” and connect your Nuki Bridge.
  2. Click on the Nuki Bridge symbol and activate “API quick connection” and “HTTP API”.
  3. Make a note of the IP address, port, and API token.
  4. In the iHaus app, go to the desired room and select “+ add” “New devices and services” “Nuki Bridge” and enter the relevant data.
  5. Your Nuki Smart Lock will be displayed under “found devices” and can be integrated into your Smart Home via LINKIT as usual.
