The Nuki Smart Lock is designed for standard compatibility with a wide range of Smart Home systems.
With the Nuki Skill for Amazon Alexa, you can easily control your Nuki Smart Lock with your Echo devices and all other Alexa-compatible devices. Check the status of your Smart Lock at any time and have Alexa open your door when your guests arrive.
Find more information about Alexa Skills on our blog.
Setup
You need a Nuki Web account to activate the Amazon Alexa Skill.
- Activate Nuki Web in your Nuki App ("Settings" > "Features & Configuration" > "Activate Nuki Web").
- Select "Amazon Alexa" in the “Features & Configuration” section in the Nuki app.
- Tap on "Connect now" to link your Nuki Web account with Alexa.
- If the Alexa app is installed on your smartphone, it will open automatically and you can link your Nuki Web account with Alexa.
Alexa is NOT installed on your smartphone? You will be redirected to the web view of the Amazon login page. Login to your Amazon account and link your Nuki Web account to Alexa.
Now, you can ask Alexa via voice control to lock or unlock the door for you.
Learn more about Nuki Web & Amazon Alexa:
In addition to Nuki Web, you can also use the new Matter communication standard to integrate Nuki into your smart home:
Matter capable Smart Home Hubs
The new communication standard Matter enables seamless integration of your Smart Lock (4th Generation) into your Smart Home.
Currently, you can use Matter integration with Apple Home, Samsung SmartThings, Google Home and Amazon Alexa.
Learn more about:
