What are the improvements of the new Power Pack generation?
The new Power Pack technology improves efficiency and battery life.
Here's what you can expect from the new Power Pack:
1) Optimized power supply for your Smart Lock
2) Reduced leakage of energy in standby mode
3) Significantly extended battery life
Compared to the previous version, the new Power Pack has a lower nominal energy capacity (2.05 Ah). At the same time, the integrated cells deliver more usable energy due to lower self discharge rate effectively leading to a longer battery life of the Smart Lock.
With this innovation, you won't need to recharge your Power Pack as frequently, and your Smart Lock will be optimally powered.
