Switching to another connection method for remote access
This article concerns:
  • Smart Lock (4th Generation)
  • Smart Lock Pro (4th Generation)
You can control your Smart Lock via Thread even when you're on the go using the Nuki App. For remote access, the Thread uplink of your Matter connection is used. Please note that this feature can only be used if it is supported by your Matter hub*.
Depending on the Smart Lock variant, you can activate remote access to your Smart Lock in different ways.
*Remote Access via Thread is currently only supported by Apple devices (HomePod, HomePod Mini, Apple TV) and Home Assistant.
Delete Bridge connection
Option 1 - Smart Lock with Bridge
Remote Access via Thread to be established
If your Smart Lock is paired to a Bridge, you need to first disconnect the Bridge connection. To do so, open the Matter settings in the Nuki App and tap onto the button „Delete Bridge connection”.
After deleting the Bridge connection the Remote Access via Thread is automatically established, provided that you are using a Smart Lock Pro.
If you have a Smart Lock in the standard variant, a one-time payment of €49.00 is required for activation.
Built-in Wi-Fi
Option 2 - Smart Lock Pro with activated Wi-Fi module
If you have already activated the built-in Wi-Fi module, the Wi-Fi connection will be automatically deactivated, and Remote Access via Thread will be established.
If the Thread network does not support an internet connection or it is not available, your Smart Lock will continue to use the Wi-Fi connection.
Remote Access via Thread enabled
Option 3 - Smart Lock Pro with Remote Access via Thread
Remote access via the built-in Wi-Fi to be established
If you want to change the remote access connection from Thread to Wi-Fi, you have to simply disable the option „Remote Access” in the Matter setting. After that, go to „Features & Configuration” > „Built-in Wi-Fi” in the Nuki App and ensure that he Wi-Fi is correctly set up.
Option 4 - Smart Lock with Remote Access via Thread
Remote access via Bridge to be established
If you want to change the remote access connection from Thread to the Bridge, simply pair the Bridge using the Nuki App. This will automatically turn off Remote Access via Thread.
