Locking the Smart Door via button or key
You can lock or unlock your door by pressing the Button on the inside of the door. Alternatively, you can simply turn the mechanical key on the outside of the door.
Auto Lock on the Smart Door
The Auto Lock feature automatically locks your door when it has been unlocked for a certain period of time or after a door opening/closing action. If the door remains closed, the door will be locked after the period of time previously set in the Nuki app.
In order to customize the Auto Lock parameters, tap on the desired Smart Door in the Nuki app and enter the lock settings. Then go to “Manage Smart Door”. Here you can configure the “Auto Lock” feature and select the desired time (30 sec – 30 min) after which the Smart Door should lock the door.
Automatic locking actions triggered by the Auto Lock feature are documented in the activity log.
Lock ’n’ Go on the Smart Door
If Auto Lock is disabled, and you press the button on your Smart Door twice, the door will be unlocked (if it is not already unlocked) and locked again automatically after 20 seconds.
If you have started the Lock ’n’ Go feature and want to cancel it, just press the button on your Smart Door again.
The Lock 'n' Go feature is especially useful if you want to leave your home. When you press the button on the Smart Door twice, you have 20 seconds to go out the door. After 20 seconds, the Smart Door will be locked behind you. Your smartphone remains in your pocket.
