The Nuki Power Pack is a powerful rechargeable battery pack for your Nuki Smart Lock. It is compatible with every Nuki Smart Lock and can easily be swapped into or out of your Nuki Smart Lock or Nuki Smart Lock 2.0.
The Nuki Power Pack is charged via USB-C cable. The scope of delivery includes a standard USB-C charging cable (50 cm, USB-A to USB-C).
Mounting the Power Pack
First remove the battery compartment of your Smart Lock. The battery compartment is located on the bottom of the Smart Lock. To open it, push the small lever in the direction of the arrow. When the battery compartment is removed from the Smart Lock, you can simply plug in the Power Pack.
