The Nuki Power Pack is a powerful rechargeable battery pack for your Nuki Smart Lock. It is compatible with every Nuki Smart Lock and can easily be swapped into or out of your Nuki Smart Lock.
The Nuki Power Pack is charged via USB-C cable. The scope of delivery includes a standard USB-C charging cable (50 cm, USB-A to USB-C).
Mounting the Power Pack
Please charge your Power Pack with the enclosed USB cable before first use.
For optimal performance we recommend the Amazon 5W USB Original Charger and Power Adapter.
After an average charging time of about 10 hours your Power Pack is fully charged. During the charging process the LED flashes. Once the LED stops blinking the Power Pack will be fully charged the LED turns off.
First remove the battery compartment of your Smart Lock. The battery compartment is located on the bottom of the Smart Lock. To open it, push the small lever in the direction of the arrow. When the battery compartment is removed from the Smart Lock, you can simply plug in the Power Pack.
Please note that compared to the battery compartment you have to use more force to insert the Nuki Power Pack into the Smart Lock. It is best to stabilise the Smart Lock with one hand from above while pushing the Power Pack upwards until you hear the typical clicking sound.
