The Nuki Keypad is mounted on the outside of your front door by gluing it to the door frame or screwing it to the front of the house. The Keypad can be assembled and used by anyone in just a few minutes. Two button cells power the Keypad, eliminating the need to connect wires or cables. The Keypad must be within Bluetooth range of the Smart Lock.
The Keypad can be used with any Nuki Smart Lock. Keypad management is done using the Nuki app.
Stick Keypad to the door frame
1) Clean the door frame so that it is free of dirt and grease.
2) Remove the adhesive backing from the back of the Keypad.
3) Fix the keypad to the desired position on the door frame.
4) Open the Nuki App on your smartphone and set up your Nuki Keypad with it. Open the Nuki App menu and choose "Manage Keypad".
Screw Keypad to the wall
1) Open the case of the Nuki Keypad by applying pressure to the bottom of the Keypad and pulling it from the back plate.
2) Mount the back plate of the Nuki Keypad to the wall. Use the enclosed mounting material. Simply screw through the silicone covers at the inside of the two holes. The silicone covers serve as waterproof seals to prevent water from getting into the Keypad case.
3) Then close the case of the Keypad so that the outer silicone cover seals tightly at all edges.
