Mounting instruction for your Keypad
The Keypad can be assembled and used by everybody in just a few minutes.
The Nuki Keypad is designed for DIY installation. Wires or cables do not have to be connected during installation because batteries power the Keypad. Thus, installation and setup can be done by everybody in just a few minutes.
Please note that the Keypad must be within Bluetooth range of the smart access solution (Smart Lock, Opener or Smart Door) when installing your Keypad.
Keypad Installation with adhesive plate
1) Clean the door frame until it is free of dirt and grease.
2) Remove the adhesive cover from the back of the Keypad.
3) Fix the Keypad to the desired position on the door frame.
4) Open the Nuki app on your smartphone and open the menu (top left). Now select "Manage my devices" and "Keypad". The app will guide you through the setup.
Installation with screws
1) The backplate of the Keypad has two mounting holes. Use two anchors and two screws (M 3.5 x 30mm; not included) to attach it to the house wall.
2) Mount the backplate to the house wall using the screws.
3) Attach your Keypad to the backplate.
The Keypad 2 is also available in the Pro variant.
The Keypad 2 Pro is designed for seamless installation in a wall or door. The direct power connection provides added convenience. Therefore, installation requires cutting and wiring. Nuki recommends having the installation performed by a professional.
Here you can find Nuki partners who can provide you with competent advice.
Support Chat Chat status:
