Keypad batteries
Replacing the batteries
To replace the batteries of the Nuki Keypad, open the housing by detaching the lower part of the keypad from the upper one - this can be done easily without tools. If necessary, use a flat-head screwdriver to remove the batteries, if the batteries are not too easy to remove. Now insert two new CR2032 batteries (button cells) and close the case carefully.
Keypad
Batteries - lifetime
The Nuki Keypad is battery operated and comes with two button cells (CR2032). The average life of the batteries is 12-18 months; this corresponds to about 30,000 lock actions. If the batteries of the keypad are empty, you will need your smartphone, Nuki Fob or the physical key to open your door.
Support Hotline Due to the current high ticket volume we regret to inform you that our hotline is not available at the moment. We kindly ask you to send us your request by using the contact form.
