Opening the door via entry codes
With the Nuki Keypad you can easily open your door by entering a 6-digit entry code. You can create up to 100 individual entry codes for your Keypad.
Lockig the door with the Keypad
During the setup of your Keypad, you can decide whether you only want to open the door with the Keypad or also lock the door with it. There are the following options:
1.) Lock with back key: When the door is unlocked and you press the back button on the Keypad, Nuki locks the door.
2.) Lock with entry code: When the door is unlocked and you enter the entry code on the Keypad, Nuki locks the door.
3.) Do not lock: Use the Keypad only for opening the door.
Manage entry codes
With the Nuki app you can create up to 100 individual entry codes for your Keypad. With the Nuki Bridge this even works from afar. The 6-digit Keypad entry codes can be limited in time, just like normal Smart Lock permissions.
To manage the entry codes for your Keypad, tap on the desired Smart Lock in the Nuki app and enter the lock settings. Then go to "Manage users" and switch to the "Entry codes" tab, where you can create a new entry code. You can share the generated entry codes with the person of your choice.
Activity log
With the help of the activity log in the Nuki app you can always keep track of who enters your home and when. In the log you can also see when a wrong entry code has been entered.
