Add & manage Smart Lock users
Add a Smart Lock via Bluetooth
To pair a Smart Lock via Bluetooh with your Nuki app, proceed as follows:
1) Install the Nuki app on your smartphone.
2) Open the Nuki app on your smartphone an choose “Set up Smart Lock”. Follow the instructions in the Nuki app to pair the Smart Lock with the app.
3) When the pairing is complete, you can lock the Smart Lock with your smartphone.
To prevent guests from pairing your Nuki Smart Lock directly with other smartphones, deactivate the “Bluetooth Pairing” option.
Open your Nuki app and go to: Settings > Manage Smart Lock and disable the option "Bluetooth Pairing".
When Bluetooth Pairing is deactivated, you can only add new Smart Lock users via invitation code.
Share access permissions for your Smart Lock
With the Nuki app you can share access permissions with your family and friends. If you have a Nuki Bridge, this even works from afar. You can share invitation codes with your Nuki app, e.g. via text message or email.
To generate an invitation code, tap on the desired Smart Lock in the Nuki app and enter the lock settings. Then go to "Manage users" and choose “Invite user”. By creating the invitation Nuki generates an invitation code which you can share with the invited person.
Invitation codes can only be redeemed once within 48 hours.
Add a Smart Lock via invitation code
To add a Smart Lock via invitation code, proceed as follows:
2) Open the Nuki app on your smartphone an choose “Enter invitation code”.
3) After entering a valid invitaiton code, you can lock the Smart Lock with the new smartphone.
Manage users
To manage users, tap on the desired Smart Lock in the Nuki app and enter the lock settings. Then go to "Manage users". Then you can see the already authorized users and you can edit them, or invite new people to access your Smart Lock. If you have a Nuki Bridge, this even works from afar.
To invite persons to your Nuki in an instant, you can also open the menu (top left) and choose "Invite person".
Support Chat Chat status:
