Improving the connection between your Nuki device and the Nuki Bridge
How you can increase connection quality and stability
Your Nuki device is connected to the Nuki Bridge but not available from afar? Here you can find simple steps to optimize the connection:
  • Check Bluetooth connection
    The connection between Bridge and Nuki device is influenced by the distance between the devices.
    Plug the Nuki Bridge into a power socket that is no more than 5 meters away from the paired device. Obstacles like walls or doors between the devices reduce the connection quality.
  • Check Wi-Fi connection
    Make sure that your Bridge has a good Wi-Fi connection to your router. If necessary, reduce the distance between your router and your Nuki Bridge to optimize the Wi-Fi signal strength.
  • Reboot devices
    - Unplug the Bridge for a few seconds and plug it in again.
    - Disconnect your Wi-Fi router from power for a short time.
    By interrupting the power supply, your devices will reboot.
  • Update devices
    Make sure that the latest firmware version is installed on your Nuki devices. Also use the latest Nuki app version.
Note: You can check the connection quality under "Settings" > "Connection Status". Learn more
SmartLock3.0-White-Pic1
Opener-White-Pic1
Support Hotline Due to the current high ticket volume we regret to inform you that our hotline is not available at the moment. We kindly ask you to send us your request by using the contact form.
