The Nuki app guides you through the initial setup of your Nuki devices.
To set up your first smart access solution with the Nuki App, install the Nuki App on your smartphone and open it. Then follow the steps as described in the app.
You can add a new access solution on site via Bluetooth.
If you have received an invitation code for a device, select "Enter invitation code" in the app.
Additional devices can be added to your app at any time in the main menu of the Nuki app (top left, three yellow bars) under "Manage my devices". Whether smart access solutions (Nuki Opener, Smart Lock, Smart Door) or smart accessories - every Nuki device can be set up via the menu. Just follow the instructions in the Nuki app.
Information about the initial setup of all Nuki products can be found in the product categories in the help section:
