Yes, you can continue to lock your door from the outside with the key if your cylinder is equipped with an emergency function or priority function. This means that you can lock your door lock from the outside, even if there is a key inside the lock. It is important that the key inside the lock turns synchronously with the key on the outside. The cylinder must have this feature to ensure that the Smart Lock does not lose its position after locking the door with a physical key. You can find out whether your door lock is equipped with this feature by using our installation check.
Can I continue to lock my door with my key?
105 out of 157 found this helpful
International: | +1 (915) 600-7233 |
Germany: | 0800 880 8710 |
Austria: | +43 720 880010 |
Switzerland: | 0800 880 871 |
United Kingdom: | +44 1688 212012 |
Mon-Fri: | 9am-6pm (CET) |
Email Support
Send us an email, if you have any questions.
