The Keypad can only be paired with one Nuki device.
If you pair your Keypad with a new device, the connection to the previously connected device will be disconnected. Learn more.
With the Nuki app you can share up to 200 access codes with family and friends. If you have online access to your device, this even works remotely. Entry codes can be limited in time and also be deleted again, just like every other device permissions.
If you have the Keypad 2.0, you can create 20 fingerprints in addition to the entry codes.
