You can simply and quickly generate up to 200 entry codes with the Nuki app.
Creating a new entry code
1. Open the settings of the Nuki device connected to the Keypad in the Nuki app.
2. Select "Lock permissions" > "Keypad".
3. Use the option "Add permission" to create a new entry code.
Deleting an entry code
2. Select "Lock permissions" > "Keypad". Now you will see the already authorized entry codes for your device.
3. Select the code you wish to delete and tap on "Delete entry code" at the very bottom.
