You can simply and quickly generate up to 200 entry codes with the Nuki app.
Creating an entry code
To create an entry code, tap on "Manage my devices" in the Nuki app, then select the desired Smart Lock and go to the lock settings. Subsequently select "Manage users" and switch to the "Entry codes" tab. Here, you can create a new entry code. You can then share the generated entry code with the desired person.
Deleting an entry code
To delete an entry code, you follow the same steps for creating an invitation code to get to the user management screen. Then switch to the tab "Entry codes". Under the "Keypad entry codes" point, you will find an overview of all codes which have been assigned for this Smart Lock. Select the code you wish to delete and tap on "Delete entry code" at the very bottom.
You can find out more about managing entry codes here.
