What are the necessary conditions for the Bridge?
In order to connect your Nuki device to the Internet and control it remotely, you need the Nuki Bridge. For this, your Bridge needs to receive a Wi-Fi signal with 2.4 GHz (standard version). The Nuki Bridge can generally be used with all common sockets (power supply of 110 to 240 V). Please note that a socket in the immediate vicinity (<5 m distance) of the Nuki device should be used to guarantee an optimal connection between the Bridge and the other Nuki device.
Click on the following link to find more information on the ideal alignment of the Bridge to guarantee a stable connection to your Nuki device.
The Smart Lock Pro has an built-in Wi-Fi module, which allows you to connect your Smart Lock to your Wi-Fi in a few simple steps without any additional accessories.
