Interaction with Amazon Alexa
With Amazon Alexa you can lock your door easily via voice control.
Here we show you some examples of how you can interact with Alexa.
Interaction with Alexa
Examples for names and commands:
Nuki:
"Alexa, lock Nuki."
"Alexa, unlock Nuki."
“Alexa, is Nuki locked?”
Home:
"Alexa, lock Home."
"Alexa, unlock Home."
“Alexa, is Home locked?”
Front door:
"Alexa, lock the front door."
"Alexa, unlock the front door."
“Alexa, is the front door locked?”
Troubleshooting
Alexa doesn't recognize the name of your Nuki Smart Lock?
Alexa takes the name of the device from your Nuki web account.
If you want to change the name or if Alexa doesn’t recognize the name of your Nuki device, change it directly in your Alexa app. To do so, open the Amazon Alexa app and choose "Skills" in the menu. Go to the "Nuki Smart Home" and then to "Settings" > "Manage Smart Home Devices". Select the Smart Lock you want to use, then tap "Edit" and "Edit Name" in the upper right corner. This name must be included in all commands so that Alexa knows which Smart Home device should be locked.
Learn more about Nuki & Amazon Alexa:
Activate the Amazon Alexa Skill
Supported features
Note: To use the Nuki Skill for Amazon Alexa you need remote access to your Smart Lock and a free Nuki Web account.
In addition to Nuki Web, you can also use the new Matter communication standard to integrate Nuki into your smart home:
Matter capable Smart Home Hubs
Nuki_SL_Badges The new communication standard Matter enables seamless integration of your Smart Lock (4th Generation) into your Smart Home.
Currently, you can use Matter integration with Apple Home, Samsung SmartThings, Google Home and Amazon Alexa
Learn more about:
