With your order of a Nuki Smart Lock you will receive our revised mounting plates for a secure and stable installation on your door. Included in delivery are:
1) the mounting plate A, which is directly fixed to the cylinder by three screws, and
2) the mounting plate B for cylinders with less than 3mm overhang on the inside of the door. The Mounting plate B is glued to your door with special adhesive pads.
Instructions for mounting and using the different versions of mounting plates can be found here.
The revised mounting plates are made of black, glass-fibre reinforced plastic. They are characterised by durability and a maximum of stability. As the colour of the mounting plate is not visible after the installation of the Smart Lock, the new mounting plates are also suitable for Nuki Smart Locks of our White Edition.
By changing the production of the mounting plates, we have also succeeded in achieving the highest quality and stability at a significantly reduced unit price. The resulting price advantage leads directly into the price reduction already implemented for our customers in autumn 2020.
