Opening the door with the Nuki app
Opening the door with the Nuki app via buttons or swipe gestures
With the Nuki App you can control your intercom system’s buzzer by using buttons or swipe gestures.
Tap on the Opener in your Nuki app and choose a button with the desired action. You have the choice between:
- Open
- Ring To Open
By swiping left or right you open your door quickly. The default setting for swipe gestures is “Open”. You can change the settings for swipe gestures by tapping on the Opener in the Nuki app and opening the settings of the Opener. Then select "Swipe Actions" > “Swipe right” or “Swipe left”, to adapt the feature to your personal preferences.
Note: The Opener communicates via Bluetooth (BLE). However, since a Bluetooth connection between your apartment and the front door of your building is usually not stable enough, or there might not even be a connection at all, we recommend using the Opener together with the Nuki Bridge, which is connected to the internet by Wi-Fi.
