By activating the ring suppression, the ring signal of your intercom system is suppressed, if this is technically possible
Due to technical differences of the intercom systems, ring suppression cannot be guaranteed. Therefore, ring suppression is only available if your intercom system supports this feature technically.
If your system supports this feature, you can activate the “Ring suppression” for the following actions according to your personal needs:
- Ring
The ring signal is suppressed as soon as the doorbell is operated. - Ring To Open
The ring signal is suppressed as soon as the doorbell is operated and “Ring to Open” is active. - Continuous mode
The ring signal is suppressed as soon as the doorbell is operated and the “Continuous mode” is active.
If you still (or partially) hear the ring signal the Nuki support team will help you to manually adjust the ring suppression.
