If the cylinder has an overhang of less than three millimetres, Mounting plate B must be used.
On a clean and level surface, mounting plate B will adhere permanently, as long as it completely lies on the surface. If Mounting plate B is used correctly, permanent and stable assembly can be guaranteed.
The stability of the adhesive surface particularly depends on the size of the surface above which the mounting plate adheres to the base. The larger the area of the adhesive surface, the more stable the assembly.
