How do I remove the adhesive pad?
To remove the adhesive tape of the Mounting plate B from your door, we recommend cutting through the adhesive with a flat object (e.g. a butter knife). Additionally remove the mounting plate by rotating it.
The rest of the adhesive tape can now be rolled off the surfaces with your thumb. Small residues of the adhesive pad can be picked up with larger ones. That way you should be able to remove the adhesive tape completely.
Support Hotline Due to the current high ticket volume we regret to inform you that our hotline is not available at the moment. We kindly ask you to send us your request by using the contact form.
