- Door Sensor
- Smart Lock 3.0 and newer
The Door Sensor is suitable for plastic and wooden doors. Sliding doors and doors made of metal are not supported, as they influence the measurement of the magnetic field strength. The Door Sensor offers variable mounting options on the door and the door frame. This way external influences can be reduced, increasing reliability.
With an ideal positioning you can achieve highest reliability of the door status detection. Depending on your door, the optimal position for sensor and magnet differs:
Option A - The door and the door frame are at the same level
If the door and the frame are at the same level, the magnet must be mounted parallel to the Nuki Door Sensor on the inside of the door. The distance between sensor and magnet must be in the range of 0.5 cm and 3 cm.
Option B - The door and the door frame are not at the same level
If the door and the door frame are not on the same level, position the magnet on the edge of the door at a 90° angle to the sensor.
The distance between magnet and sensor should be between 0.5 and 3 cm for this mounting option as well.
The Smart Lock 1.0 and 2.0 are not compatible with the Door Sensor. However, the Smart Lock 2.0 has a built-in door sensor (beta). Learn more about the installation of the built-in door sensor of the Smart Lock 2.0.
