Open the door with your Huawei smartwatch
With the Nuki Huawei HarmonyOS Watch App app you can open your door from your wrist.
One of the most significant advantages of smartwatches is that you don't need your smartphone so often. From now on, you can even leave it at home. Because in Bluetooth range you can control your Nuki device directly via your watch.
Installation & Setup
  1. Make sure your Watch and smartphone are connected.
  2. Open the Huawei AppGallery and install the Nuki app on your watch.
  3. Open the Nuki app on your smartphone and select "Connect Huawei Watch" in the menu. The connection to your watch will be established.
  4. Select the desired Nuki device.
    You can control up to three Nuki devices via your watch.
From now on you can control your Nuki device via your smartwatch!
What you should know about Nuki & Huawei
  • Direct Bluetooth communication
    Within Bluetooth range, you can control your Nuki device directly via your watch. You don’t need to have your smartphone with you.
  • Communication via your smartphone
    The Nuki Opener can also be controlled remotely by using your smartwatch. However, for this you also need your smartphone. The smartphone can stay in your pocket as long as your watch and smartphone are within Bluetooth range.
  • Compatibility
    Our wearable application only supports Huawei wearables (Huawei Watch 3 / Watch 3 Pro) Lite/sport wearables like the GT3 Pro are not supported.
  • Language availability
    You can use your app on your smartwatch in English, German, Italian, Spanish and Dutch.
Tip: In case of connection problems or errors in the status display, always reboot your smartphone and your watch.
Support Hotline Due to the current high ticket volume we regret to inform you that our hotline is not available at the moment. We kindly ask you to send us your request by using the contact form.
