With the Nuki Huawei HarmonyOS Watch App app you can open your door from your wrist.
One of the most significant advantages of smartwatches is that you don't need your smartphone so often. From now on, you can even leave it at home. Because in Bluetooth range you can control your Nuki device directly via your watch.
Installation & Setup
- Make sure your Watch and smartphone are connected.
Please note that the “Huawei Health” app must be installed. If the "Huawei Health" app is not yet installed, you can download it from the Huawei AppGallery on your smartphone. - Open the Huawei AppGallery and install the Nuki app on your watch.
- Open the Nuki app on your smartphone and select "Connect Huawei Watch" in the menu. The connection to your watch will be established.
The menu item "Connect Huawei Watch" is only displayed if the “Huawei Health” app has been installed before. - Select the desired Nuki device.
You can control up to three Nuki devices via your watch.
From now on you can control your Nuki device via your smartwatch!
What you should know about Nuki & Huawei
- Direct Bluetooth communication
Within Bluetooth range, you can control your Nuki device directly via your watch. You don’t need to have your smartphone with you. - Communication via your smartphone
The Nuki Opener can also be controlled remotely by using your smartwatch. However, for this you also need your smartphone. The smartphone can stay in your pocket as long as your watch and smartphone are within Bluetooth range. - Compatibility
Lite Wearables (Huawei GT2 Pro / GT3 / GT3 Pro) cannot be used with Nuki.
Also, currently not supported are Huawei Watch 4 and Huawei Watch Ultimate. - Language availability
You can use your app on your smartwatch in English, German, French, Italian, Spanish and Dutch.
Tip: In case of connection problems or errors in the status display, always reboot your smartphone and your watch.
