Tamper Detection
Maximum security through highest reliability and integrated tamper detection
The Nuki Door Sensor allows you to see if the sensor is mounted properly. As soon as the Nuki Door Sensor is no longer fixed to the door, this will be registered by the tamper detection and communicated to your Smart Lock. Of course you will receive a notification if the door sensor has been removed.
Using the tamper button on the back of the sensor you also can set up your Nuki Door Sensor and pair it with your Smart Lock.
Due to the very high reliability as well as the integrated tamper detection the Nuki Door Sensor offers additional security for your smart home!
Door sensor with displayed battery compartment, tamper detection, led, mounting plate
