More power for your Smart Lock with the Nuki Power Pack
The Nuki Power Pack is a powerful rechargeable battery pack for your Nuki Smart Lock ensuring an optimal power supply and battery life of up to 6 months.
With the rechargeable battery pack there is no need to change the battery anymore. The Nuki Power Pack is charged via USB-C cable. Included in the delivery is a standard USB-C charging cable (50 cm, USB-A to USB-C). Charging can be done while using your door, thus enabling a permanent power supply for your Nuki Smart Lock.
The Nuki app helps you to keep track of the battery level. You will be informed by a flashing LED of the Smart Lock and by a notification when the battery level drops below 20%.
Note: The Nuki Smart Lock 3.0 Pro includes the Nuki Power Pack. All other versions of the Nuki Smart Lock come with four standard AA batteries. However, you can use every Nuki Smart Lock with the Nuki Power Pack. This way you benefit from an optimal power supply and battery life of up to 6 months.
Buy the Nuki Power Pack and power up your Smart Lock.
Mounting the Power Pack
First remove the battery compartment of your Smart Lock. The battery compartment is located on the bottom of the Smart Lock. To open it, push the small lever in the direction of the arrow. When the battery compartment is removed from the Smart Lock, you can simply plug in the Power Pack.
