Take three minutes to find out whether you can install the Nuki Smart Lock on your door.
With our installation check, you can find out if your door lock is compatible with Nuki. You fasten or stick the Smart Lock to your existing cylinder on the inside of the door. This means both variants can be removed without leaving a trace, making them ideal for renters.
Since your Smart Lock is mounted on the door from the inside, no one on the outside can tell that you’re using an electronic door lock. Using a smart lock does not affect your insurance coverage.
