Door sensor of the Smart Lock 2.0 | Nuki Door Sensor | |
Hardware | The door sensor is built into the Smart Lock 2.0. | The Nuki Door Sensor is a hardware accessory. |
Housing | No housing | Plastic white housing for sensor and magnet |
Compatibility | Smart Lock 2.0 | Smart Lock 3.0 Smart Lock 3.0 Pro Smart Lock (4th generation) Smart Lock Pro (4th generation) |
Mounting | - The sensor is built into the Smart Lock 2.0. - The magnet is mounted via an adhesive pad. You only have limited mounting options. The influence of external factors can therefore lead to reduced reliability. |
The sensor and the magnet are mounted via an adhesive pad. A mark on the sensor indicates the ideal position of the magnet. |
Bluetooth | BLE 4.0+, i.e. BLE 5 support | BLE 4.0+, i.e. BLE 5 support |
Features | - Door status detection - Calibratable - Status signalisation via Smart Lock LEDs |
- Door status detection - Calibratable - Status signalisation via Smart Lock LEDs - Tamper detection - LED for status symbolisation during pairing and setup - very high reliability |
Batterylife | No independent power supply | 2 years 3,6V Lithium battery |
How does the integrated door sensor of the Smart Lock 2.0 differ from the Nuki Door Sensor?
158 out of 217 found this helpful
