Status and warnings at a glance
The status of your door is not only shown in the Nuki app but also directly on the Smart Lock by a LED signalization on the rotating ring.
Note: In addition to the illuminated ring, the Smart Lock 3.0 has a red LED in the upper segment of the ring. This LED is used to display errors and warnings directly on the Smart Lock. If the red LED lights up, open the Nuki app to get further information about the error or warning and troubleshooting steps.
Signalization on the Smart Lock 3.0 (Pro)
State | LED signalization | |
Smart Lock locked, inactive | The LED ring is off. | |
Smart Lock unlocked | The top segment of the LED ring flashes 1x every 1.5 seconds. | |
Pairing mode The Smart Lock can be connected with other Bluetooth devices. |
The LED ring is permanently glowing. | |
Maintenance mode The firmware of the Smart Lock can be updated or reset to factory settings. |
The top segment of the LED ring is permanently glowing. | |
Nuki Door Sensor Door open |
The upper segment of the LED ring is permanently glowing. | |
Nuki Door Sensor Door closed |
The lower segment of the LED ring is permanently glowing. | |
Error | LED signalization | |
- Battery state crititcal Please replace the batteries. - Battery state of the Nuki accessory (Keypad or Door Sensor) critical Please replace the batteries. - No Wi-Fi connection - Nuki Door Sensor removed |
The red segment of the LED ring flashes 1x every 15 seconds (in total 4x). Note: The error signalization is displayed directly after the locking action. |
Uncalibrated The Smart Lock is not calibrated. The status was lost due to external influences. Please calibrate it with the Nuki app. |
The red segment of the LED ring flashes 4x every 15 seconds. |
Signalization on the Smart Lock (Version 1) and Smart Lock 2.0
Battery state crititcal Please replace the batteries. |
Unlocked state: The top segment of the LED ring flashes 3x every 5 seconds. Locked state: The top segment of the LED ring flashes 2x every 10 seconds. |
Motor blocked Make sure that your Smart Lock is mounted correctly and the door is unlocked and open. |
After a locking operation the LED ring flashes evenly for 10 seconds. After that, the top segment of the LED ring flashes 3x every 15 seconds. | |
The top segment of the LED ring flashes 6x every 15 seconds. |
