Due to a technical error, the connection to Google Home, Amazon Alexa or IFTTT may have been lost. Therefore, please check the correct functioning of your integration and re-establish it if necessary.
Amazon Alexa
How can I reconnect Amazon Alexa?
A guide for the necessary steps to (re-)connect Nuki devices with Amazon Alexa can be found here.
Google Home
How can I reconnect Google Home?
A guide for the necessary steps to (re-)connect Nuki devices with Google Home can be found here.
IFTTT
How can I reconnect my Smart Lock with IFTTT?
Go to ifttt.com/nuki/settings and check the status. You can also reconnect here. We recommend disconnecting completely ("Remove") and then reconnect.
How can I reconnect my Opener to IFTTT?
Go to ifttt.com/nuki_opener/settings and check the status. You can also reconnect here. We recommend disconnecting completely ("Remove") and then reconnect.
The IFTTT service is connected, but the applets are still not running?
You can check at ifttt.com/home whether your applets are active and also reactivate inactive applets. Best also check at the Applet settings (top right per applet)if your Nuki device is selected correctly.
