The Nuki Universal Cylinder is compatible with almost every door in Europe
Check the profile and dimensions of your cylinder to make sure the Nuki Universal Cylinder is suitable for your door.
Which cylinder profile is supported?
The Nuki Universal Cylinder is a Europrofile cylinder. If your door is equipped with a Europrofile cylinder, you can replace it with the Nuki Universal Cylinder. If you are currently using a cylinder of a different design (Swiss Round Cylinder, UK Oval Cylinder etc.) the Nuki Universal Cylinder is not suitable for you.
Which cylinder dimensions are supported?
Developed as a modular solution, the Nuki Universal Cylinder is easy and straightforward to lengthen or shorten to the right size. This means there are 33 possible cylinder dimensions that make the Nuki Universal Cylinder compatible with almost every door in Europe.
The Nuki Universal Cylinder offers you three external dimensions and eleven internal dimensions.
External dimensions | Internal dimensions |
32 mm | 30 mm |
37 mm | 32.5 mm |
42 mm | 35 mm |
37.5 mm | |
40 mm | |
42.5 mm | |
45 mm | |
47.5 mm | |
50 mm | |
52.5 mm | |
55 mm |
