Add and manage entry codes
Manage all access rights to your home via your Nuki app
With the Nuki app you can create up to 200 individual entry codes for your Keypad. If you have online access to the device, this works even from afar.
Of course, you can also set a time limit for an entry code and edit or delete it at any time:
  • Open the settings of the Nuki device connected to the Keypad in the Nuki app.
  • Select the option “Keypad” in the section “Lock permissions”. Now you see - if already created - the already authorized entry codes.
  • To edit or delete an existing entry code, simply tap on the desired permission. You can now change the permission details or delete the entry code.
  • To create a new entry code, tap on "Add permission". Now choose a 6-digit entry code and, if you want to, share the code with other people.
With the Keypad 2 you can also add a fingerprint after creating the entry code. Learn how to create a fingerprint.
Support Chat Chat status:
