Compatible Short Rental integrations
This article concerns:
  • Nuki Smart Hosting
With Nuki Smart Hosting, you can connect Nuki directly to systems like Airbnb, Smoobu, Guesty and many more. This way you can automate the key handover and save yourself extra trips and waiting times. If you change the booking, Nuki adjusts the access permission automatically for you. And after check-out, your guests’ entry code automatically expires.
Internal integrations
You can set up these partner integrations directly via your Nuki Web account. We have linked the detailed instructions for setting up the integrations:
Partner integrations
Nuki has already been integrated into the apps of many partners. In these cases, setup is carried out directly via the system you are using.
Note:
If you have any questions about setup and usage of the partner integration, please contact the support of your system directly.
Here you can find information from the partner systems on integration with Nuki:
Property management software
Guest management
Guest registration
Other
