With the Keypad 2 the choice is yours: You can open your door by typing in a 6-digit entry code or by putting your finger on it.
With the Keypad 2 you can open your door conveniently with your fingerprint in just a few seconds. As an alternative, you can easily open the door with an entry code.
The fingerprint sensor also guarantees you the highest level of security.
The Keypad (version 1) does not have a fingerprint sensor. The door can therefore only be opened via entry codes.
The housing of the Keypad 2 is made of black plastic. Of course the Keypad 2 is protected against splashing water and dust (IP54).
Installation and setup of the Keypad 2 can be done by everybody in just a few minutes. An optimal power supply is ensured via four AAA batteries.
An overview of the differences between Keypad and Keypad 2 can be found here.
What are the differences between the Keypad (Version 1) and the Keypad 2?
299 out of 346 found this helpful
